Posted: May 21, 2006 at 12:07 PM / IP Logged
Posted: May 21, 2006 at 12:55 PM / IP Logged
Posted: May 21, 2006 at 1:39 PM / IP Logged
Posted: May 21, 2006 at 2:05 PM / IP Logged
Posted: May 21, 2006 at 2:40 PM / IP Logged
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Viper 791XV wiring Altima 04 NOT USING remote startPrimary Harness (H1), 12-pin connector (-) 500mA ARMED OUTPUT YES? CHASSIS GROUND?(+)/(-) selectable light flash output YES? PARKING LIGHT(-) remote start activation input NO? (-) 200mA domelight supervision output NO?(-) door trigger input, zone3 YES ANY DOOR TRIGGER(-) multiplexed input, zone4 NO?(+) door trigger input, zone3 NO(-) ground YES CHASSIS GROUNDEMPTY(+) siren output YES TO ALARM(+) constant power input YES 12V CONSTANT IGN.(-) 200mA channel 2 validity output NO?Secondary Harness (H2), 6-pin connector(-) factory disarm/special accessory output NO?(-) factory rearm NO?(-) programmable channel 4 output YES? (-) channel 5 output YES?(-) diesel wait to start input NO(-) second unlock output NO?door lock harness, 3-pin connector(-) lock, (+) unlock output YES POWER LOCK/UNLOCKEMPTY ----(+) lock, (-) unlock output NOremote start primary harness, 7-pin connector NO(-) 200mA programmable IGN2/ACC2 relay turn on(+) ignition input to alarm(-) 200mA ignition relay turn-on(-) 200mA accessory relay turn-on(-) 200mA starter relay turn-on(-) antigrind/ground when armed output(-) 200mA status outputheavy gauge inline connector key switch interface NO?(+) output to starter circuitonboard starter kill (key side)(+) high current 12v input(+) output to accessory circuit(+) output to primary ignition circuit(+) high current 12v input(+) output to second ignition circuit(+) high current 12v inputremote start secondary harness (H3), 5-pin connector NO(-) 200mA 2nd status/rear defogger - latched/pulsed(-) hood pinswitch input, zone 1(+) brake shutdown wiretachometer input wire(-) neutral safety switch input
