2002 honda odyssey keyless entry
windcalmer
Member - Posts: 31
Posted: May 30, 2006 at 7:12 PM / IP Logged
I am installing an Audiovox (Model Number AA-925)keyless entry system into a 2002 Honda Odyssey.
I need to know the following:
Does it have + or - door triggers?
Is the wiring diagram for the 2002 the same as the 2001?
(If not, I need the diagram for the 2002.)
Is there a good website that has the locations of the wiring need? (i.e. where under the dash the wires I will need will be located. With pictures or good text.)
Thank you for your time.
_____________________
"But the sons of men fought on, and slew; and Eris (Strife incarnate) gloating watched." - Quintus Smyrnaeus
swamprat323
Gold - Posts: 1,335
Posted: May 30, 2006 at 7:14 PM / IP Logged
for 2002
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+ |ignition harness            |
|          STARTER|BLACK/ white        |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
| SECOND IGNITION|yellow              |+ |ignition harness            |
|        ACCESSORY|WHITE/ black        |+ |ignition harness            |
|       POWER LOCK|BLACK/ white        |- |green 6-pin plug *1        |
|     POWER UNLOCK|GREEN/ red           |- |green 6-pin plug *1        |
|       LOCK MOTOR|WHITE/ red           |   |green 10-pin plug *1        |
|     UNLOCK MOTOR|lt. GREEN/ red       |   |green 10-pin plug *1        |
|    DISARM DEFEAT|lt. GREEN/ red       |   |green 14-pin plug *1        |
| PARKING LIGHTS +|RED / black           |   |10-pin plug *1              |
|       HEADLIGHTS|blue/red            |- |steering column             |
|     DOOR TRIGGER|BLACK/ white        |- |domelight on/off switch     |
| DOME SUPERVISION|lt. green           |- |domelight on/off switch     |
| TRUNK/HATCH PIN|tied in with door   |   |                            |
|        HOOD PIN|yellow/red          |- |right of steering column    |
|TRNK/HTCH RELEASE|*4                  |   |                            |
| FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|blue               |- |DDM in driver door          |
|       TACHOMETER|blue               |   |above the brake master *2   |
|      SPEED SENSE|blue/white          |   |PCM *3                      |
|       BRAKE WIRE|WHITE/ black        |+ |brake pedal switch          |
|     HORN TRIGGER|lt. GREEN/ blue      |- |steering column             |
|           WIPERS|blue and blue / YELLOW|- |steering column             |
| LF WINDOW UP/DN|RED / blu - RED / yel   |A |drivers window motor        |
| RF WINDOW UP/DN|blu/wht - blu/yel   |A |RF window switch            |
| LR WINDOW UP/DN|grn/red - grn/yel   |A |LR window switch            |
| RR WINDOW UP/DN|RED / blu - RED / yel   |A |RR window switch            |
|        RADIO 12V|WHITE/ blue          |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
|     RADIO SWITCH|WHITE/ red           |+ |radio                      |
| RADIO ILLUMINATE|RED / black           |+ |radio                      |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio                      |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio                      |
|       LR SPEAKER|blu/yel - brn/wht   |   |radio                      |
|       RR SPEAKER|RED / yel - brn/wht   |   |radio                      |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555H or 555U. *1 The plug is located at the bottom of the fuse box. *2 In a 2-pin test connector. *3 The PCM is located in the center console. The speed sense is located in a 32-pin plug. *4 To open and close the power sliding door with a single channel see directfax document #1085.
swamprat323
Gold - Posts: 1,335
Posted: May 30, 2006 at 7:20 PM / IP Logged
directfax #1085 is in the download section on this site. under car sercity TIPS
