1999 dodge p/u ram 1500 remote start
duallyit
Member - Posts: 17
Posted: May 30, 2006 at 8:52 PM / IP Logged
i have a problem with the locking /unlocking  i think i have it correct by using the reverse polarity? would this be the correct  unlocking and locking wiring sytem for this particular vechile ?
i also have the roll up windows when armed and start.the windows were working fine till my father stashed the wires up and now it only rolls the windows in the remote start function only .where it use to roll up in arm and remote start .could one of the diodes be bad ? cause i connected two diodes off the alarms orange wire armed - output this then would give me one wire to the killl switch relay and the other wire to the - output of window roll up .what should i check for to correct this problem ?
thnaks for your help 12 volts you have been very helpfull in my privious qustions and glad to have you helping .
john
duallyit
jmacf14
Copper - Posts: 160
Posted: May 30, 2006 at 10:25 PM / IP Logged
to the best of my know how, the 1999 ram uses the 5 wire lock system.
jmacf14
Platinum - Posts: 12,488
Posted: May 31, 2006 at 8:11 AM / IP Logged
Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is ORANGE / green, unlock is pink/green.
For the (-) when armed wire, check to make sure with a DMM that the wire is infact sending out a (-) singal when armed. If not, then it's something in the connection to the relay or it's in the unit itself.
