Clifford Matrix RSX 3.5 R/S harness, H3
geoffl
Member - Posts: 8
Posted: June 05, 2006 at 7:16 PM / IP Logged
To make a long story short, my remote broke and my truck wouldnt disarm so I unplugged the entire alarm system so my truck would start. When I plugged it back in, I can't find the "Remote Start Harness (H3) 5-pin connector". I have a 2005 F-250. Is this wire even used? I have looked all over and can't find it. Right now without it plugged in as soon as you put in the key and turn it to the "run" position, not "start" the truck will start. What should be done to fix it? Thanks in advance.
Geoff
geoffl
Member - Posts: 8
Posted: June 05, 2006 at 7:26 PM / IP Logged
It's a diesel also.
Geoff
mobilecustoms
Silver - Posts: 397
Posted: June 06, 2006 at 3:59 PM / IP Logged
just keep looking for it find where the brake wire is connected and follow it back to the connector
geoffl
Member - Posts: 8
Posted: June 06, 2006 at 8:57 PM / IP Logged
the brake wire being the wire coming off the brake pedal? Thanks.
Geoff
mobilecustoms
Silver - Posts: 397
Posted: June 07, 2006 at 5:43 PM / IP Logged
yes
geoffl
Member - Posts: 8
Posted: June 07, 2006 at 6:19 PM / IP Logged
Here is the harness I'm missing (the one circled in the link below). I followed the wire off the brake pedal and it goes to the harness that plugs into the remote start satellite module.
Click Here
Geoff
mobilecustoms
Silver - Posts: 397
Posted: June 07, 2006 at 8:59 PM / IP Logged
once you find all of the harnesses, zip tie them together so if you ever disconnect again, they are all there in one spot.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
