2006 Dodge Durango
hazmanrog
Posted: June 06, 2006 at 10:49 PM / IP Logged
Have installed a remote start with everything working fine but cannot power up the AC. All wires at Ing. harness are energized, must be one we are overlooking somwhere? Maybe at the cluster? The AC. display comes on but not the blower. Does anyone have the info We are looking for?
bluest4
Member - Posts: 37
Posted: June 07, 2006 at 12:02 AM / IP Logged
05 Durango's with ATC (Automatic Temperature Control) heating and A/C systems have an extra RED / brown (40A) 12V wire, and an extra dk. blue  (found at the  ignition harness) these wires are accessory and you should use relays.  I believe the 06 is the same way.
autostart ak
Member - Posts: 11
Posted: June 07, 2006 at 3:21 PM / IP Logged
Check for a negative accessory wire. I had an 06 Dakota with the same issues until I found a small, low current negative accessory wire. I think it was a purple or blue if I remember correctly.
AutoStart Alaska
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
