92 Cavalier Trunk Popper
3400sfiv6
Posted: June 07, 2006 at 12:20 AM / IP Logged
i bought an OEM trunk popper from the yard the other day cuz i shaved my trunk lock, now heres the thing, when i put power to the frame of the solenoid and hit the connector with ground it pops, but when i ground the connector and hit it with power, noting, or when ground the solenoid and hit the connector with power i get nothing as well
how in the bloody hell do i wire this to a switch to make it pop
thx
Lyle
mo12v
Posted: June 07, 2006 at 8:28 AM / IP Logged
Run a GROUND from the Frame of solenoid also.........
Sounds like the area where the solenoid is mounted is not Grounded
MO
3400sfiv6
Posted: June 07, 2006 at 11:20 PM / IP Logged
but its part of the frame? ill try it, but that seems odd that having it screwed to the trunk wouldnt be grounded
mo12v
Posted: June 08, 2006 at 8:34 AM / IP Logged
Trunks, like Hoods & Doors can have GROUND issues.  The Hinge can cause the problem.  I always put a GROUND Strap to any moving Door if I don't have a GROUND wire ran to the Accessory I have installed.
Sometimes you will get a GROUND when the Trunk, Door, Hood is open, but when it is closed the Hinge will actually isolate it.  Caused from Dirt, Oil, wear, etc.
MO
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
