Air Horn on Delay through factory horn
hack6500
Posted: June 08, 2006 at 3:31 PM / IP Logged
hello all, i have new truck and had some air horns laying around and hooked them up.
rather than plumb a wire for the switch, i was thinking about another solution. i really only want to use the air horns in extreme situations, such as laying on the stock horn for 2+ sec. this would allow me to be obnoxious when i needed to, and not bother many people for a simple beep-beep.
i have no details on my specific China air compressor other than 12v 20amp (i think) as it didnt have directions. currently I have it wired for negative trigger with the relay & switch under the hood and it works fine by itself.
what i am thinking of doing is taping the factory horn voltage and using a capacitor to atain my desired 2sec delay for my compressor. I have a handful of caps, but thought i would ask before i start to experiment.
has anyone done anything like this? any advise would be greatly appreciated.
hack6500
dualsport
Silver - Posts: 983
Posted: June 09, 2006 at 9:10 AM / IP Logged
Check out this prior post on airhorns, looks pretty close to what you're trying to do-
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
