viper alarm, 94 integra
mikex1021
Member - Posts: 6
Posted: June 26, 2006 at 7:39 AM / IP Logged
hi i am trying to install a viper 791xv (beleave this is the model) it is the latest viper alarm .alarm on my 94 integra, wanted to know if ne one knew what the multiplexity wire is and were do i connect it at. and the orange wire h1/1 were it goes and what it is.
ringojam
Copper - Posts: 215
Posted: June 26, 2006 at 8:37 AM / IP Logged
The orangewire is a negative armed output,used for various uses ,such as actvating a led ,starter kill relay ect,you may not need it for your application.On page 19 of the installation manual,it explains in detail what the multplex wire will do so just check it outviper alarm, 94 integra -- posted image.
Jamaica home of the worlds fastest man.
mikex1021
Member - Posts: 6
Posted: June 26, 2006 at 9:16 AM / IP Logged
im guesing that ill need it for a starter kill relay. do you know if the alarm system has all the relays that i need or do i need to install all the relays, also do you  guys know how to install the remote start on a manual trans? thanks for the info
captainzab
Silver - Posts: 606
Posted: June 26, 2006 at 11:16 AM / IP Logged
You dont need the orange wire for starter kill because its apart of the xcrs remote start relay.
You have to disable the clutch before remote start using the blue status wire to power a relay
Your not suppose to install RS on manual by the way
mikex1021
Member - Posts: 6
Posted: June 26, 2006 at 11:48 AM / IP Logged
my clutch safety switch is broken so i already had to bypass that. do i need any relays for the 791xv alarm system to be connected in my car? and can ne one give me a guide that tells me the color of the wir of the harness that goes to each wire on the car?
mikex1021
Member - Posts: 6
Posted: June 26, 2006 at 11:55 AM / IP Logged
how do i use the blue wire to power a relay and what else do i connect to the relay?
wentworth007
Member - Posts: 33
Posted: July 12, 2006 at 10:58 PM / IP Logged
dude are you an installer professionally? if not i wouldnt attempt to do this. no offense but it takes alot of time to be able to do this type of installation.
ahuman
Posted: July 15, 2006 at 10:42 AM / IP Logged
Yeah man.. it don't sound like you have to much experience to be doing this type of alarm.. (again no offense) The ammount of damage you could possibly do to the vechicle compared to having someone do it professionally is well worth it. Also it seems like your trying to do remote start on a manual, you should really look into the damage that can be done if you start the vechicle with it accidently in gear, almost no shop will run the risk of doing a remote start in anything except automati
