1997 Volvo Alarm disarm
Joe Neal
Copper - Posts: 113
Posted: July 09, 2006 at 12:12 PM / IP Logged
Any one know how to Disarm Factory Alarm on 1997 Volvo 960??  No Remotes.........
10 Times I did it.......The 1st one was the Best
captainzab
Silver - Posts: 606
Posted: July 09, 2006 at 12:17 PM / IP Logged
960 Diagram
this is the diagram here, there is no factory alarm disarm.
i assume this means you have an aftermarket alarm.
if you know alittle about car electronics, you can open the dash and look for a brain module. If you have an LED, you can follow it back to the brain.
Joe Neal
Copper - Posts: 113
Posted: July 09, 2006 at 2:19 PM / IP Logged
Thanks for the Info.......
Apparently this is either Factory or Volvo Dealer Installed.  The only Remote Customer has is Broken and the Alarm System says Volvo.............
captainzab
Silver - Posts: 606
Posted: July 09, 2006 at 3:14 PM / IP Logged
its probably a factory installed alarm not bult into the bcm
You could unplug the brain or uninstall the system yourself. i dont know if there is a T-harness where you can unplug it (i know older toyota has it)
use the diagram to help you
