2006 Dodge Sprinter
safeandsound1
Posted: August 04, 2006 at 1:49 AM / IP Logged
Can anyone help me on wiring these power locks for this vehicle.  i found the WHITE/ yellow wire under the drivers seat except now im stuck.  dont know if these locks run off resistance or what.  any info appreciated thanks.
alarm_man
swamprat323
Gold - Posts: 1,335
Posted: August 04, 2006 at 1:40 PM / IP Logged
Power Lock WHITE/ yellow   -   sw on dash or CTM, pink plug, pin 7
Power Unlock same as power lock wire
Lock Motor blue/red   5wi DKP or CTM, pink plug, pin 2
Unlock Motor BLACK/ red   5wi DKP or CTM, pink plug, pin 3
Negative pulses on this wire will alternate between lock and unlock.
The CTM (Central Timer Module) is under the driver seat.
If you encounter a problem with the door locks getting out of synch when using this wire, then use the door lock motor wires instead for lock/unlock. See DirectFax document 1700 for wiring information.
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
