791xv no remote start
ty
Copper - Posts: 137
Posted: August 08, 2006 at 6:23 PM / IP Logged
anyone hooked up this alarm with no remote start?  I have a 5speed and don't really feel like starting into a wall by accident.
I just need to know about the 7pin remote start ribbon harness, I only need to keep the (+) Yellow ignition input to alarm, and don't need the other ignition, starter, accesory relay turn on's right??
I do have the thicker wires hooked up for constant, purple and green for starter kill, and pink for ignition, just curious about the other side of the relay.  I am relocating alarm brain and don't really want to lengthen wires I don't need to.
swamprat323
Gold - Posts: 1,335
Posted: August 08, 2006 at 6:26 PM / IP Logged
no all you need is the yellow ane the ground whjen arm for starter kill. not sure what color it is in the ribbon harness may be orange
ty
Copper - Posts: 137
Posted: August 08, 2006 at 6:41 PM / IP Logged
ok so the yellow and ORANGE / black on remote start ribbon harness seen here right?..
http://www.directechs.com/guides/manuals/ig/viper/N564V_07-05.pdf
Or do you mean the orange ground when armed on the H1 primary harness?
swamprat323
Gold - Posts: 1,335
Posted: August 08, 2006 at 7:10 PM / IP Logged
ORANGE / black that for the starter kill
kaezoo
Copper - Posts: 125
Posted: August 08, 2006 at 7:39 PM / IP Logged
If you have the pink wire from the relay pack hooked up to ignition, then the alarm will get the correct ignition input through the ribbon cable. As long as you don't ground the BLACK/ white NSS wire, the remote start will never activate; don't worry about trying to disconnect the other ribbon cable wires.
ty
Copper - Posts: 137
Posted: August 09, 2006 at 1:55 AM / IP Logged
^^^well as I said the car will not ever have remote start, and it will be less wires I have to solder when relocating the brain, and I de-pin all of my harnesses so if I ever need to run remote start on another car will be no problemo.
Thanks to all who answered question.
