Factory Harness Connectors
jrilla
Gold - Posts: 1,498
Posted: January 15, 2003 at 5:55 PM / IP Logged
Does anyone know where to get the wires harness connectors that plug into factory plugs so you do not need to splice into the Ignition wires?  I have seen them mentioned before and i was curious about their price and availability.
J Rilla
Owner/Installer
AlexDelMD
Member - Posts: 7
Posted: January 15, 2003 at 5:59 PM / IP Logged
This is the only place I have seen them :
http://www.bulldogsecurity.com/shop/mall/access_tharness(1).htm
Has anyone else used them? I'm curious to hear if they are worth the cost.
brianh
Silver - Posts: 518
Posted: January 15, 2003 at 7:40 PM / IP Logged
I belive that www.crutchfield.com uses Omegas interconnect harness.  I have not used them but they look like they would save time and all the wires in the harness are oem wire gauge.  They might be sorta expensive.  Brian
jrilla
Gold - Posts: 1,498
Posted: January 15, 2003 at 9:00 PM / IP Logged
Ok I must be retarded, I cant seem to find them at Crutchfield, and I have looked at the Bulldog site and the T-harnesses look like they use connectors that are more or less the same as T taps.   Maybe the picture is bad, but they dont look like what I am looking for.  Has anyone seen them on Crutchfield.  I think I saw a post from a guy who sold the Omega harnesses. but I wouldn't be able to find it.
J Rilla
Owner/Installer
bigburt9
Member - Posts: 10
Posted: January 15, 2003 at 9:14 PM / IP Logged
On the Bulldog t-harness you actually unplug your ignition harness and plug in the t-harness and then your ignition harness plugs back into the t-harness.
bigburt9
jrilla
Gold - Posts: 1,498
Posted: January 15, 2003 at 9:27 PM / IP Logged
Have you used them yourself?  Are they pretty slick?  I guess thge picture just doesn't do them justice.  I didn't see the vehicle I was interested in one for so i might be out of luck there.  Any other info on the Omega or any other brand?  Also do the bulldog t-harnesses allow for a starter kill relay or do you have to cut the starter wire anyway?
J Rilla
Owner/Installer
AlarmTech
Copper - Posts: 101
Posted: January 16, 2003 at 1:32 AM / IP Logged
i have a box of 112 doorlock and main igntion harnesses, all made by DEI. I have a list if your interested. Most are 93-96 Ford models. all mains are pre wired with SK and terminate with older style DEI 12 pin plug. all DL's terminate in the DEI 3 pin DL plug.
I used an Omega harness on a Camry install for a neighbor back in 97 with a Crimeguard alarm, never stopped working, never needed service and he used the crap out if, he was in outside sales, so he drove everywehere. I have to say i was impressed with the reliability. But then again, i installed it Factory Harness Connectors -- posted image.
Viper Equipped
jrilla
Gold - Posts: 1,498
Posted: January 16, 2003 at 8:41 AM / IP Logged
Where did you get the Omega Harness from?  I am looking at one for a 2001 Chevy venture.  It doesn't sound like you would have one in your DEI stash.  ANyone else know where to find the Omega harnesses
J Rilla
Owner/Installer
AlarmTech
Copper - Posts: 101
Posted: January 16, 2003 at 12:35 PM / IP Logged
sorry, nothing that new......but i got the Omega harness from Crutchfield.
Why not contact Omega directly.....http://www.caralarm.com/start.html
Viper Equipped
jrilla
Gold - Posts: 1,498
Posted: January 16, 2003 at 8:08 PM / IP Logged
I must be retarded because I cant find them there either.  i will have to email them and see what they say.
J Rilla
Owner/Installer
Tuesday, May 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
