alarm central locking, 97 civic
huge
Posted: September 14, 2006 at 7:30 AM / IP Logged
i have honda civic 97 model need diagram for sentral locking it works with alarm the alarm works dut sentral locking not
Platinum - Posts: 12,488
Posted: September 14, 2006 at 8:30 AM / IP Logged
The Civic uses a (-) trigger OEM door lock system.
POWER LOCK      GREEN / WHITE        |-|   blue plug dkp or at the Factory alarm plug located behind radio. (GREEN/ plug).
POWER UNLOCK    GREEN/ orange      |-|   blue plug dkp or or at the Factory alarm plug located behind radio. (GREEN/ plug). Can also use blue / YELLOW for driver door unlock only.
If this is not an OEM system but an aftermarket system with door lock actuators added on afterwards, you would have two relays connected to the alarm module and it should be wired like this: actuator diagram
