Doors won't lock on 2006 Colorado
bigbadwhopper
Member - Posts: 6
Posted: September 16, 2006 at 6:08 PM / IP Logged
I installed keyless entry and alarm in my 2006 Colorado. Everthing went fine , I put in the actuators and wired everthing up. It all works fine, except the auto door locks. If I turn the key on , then they lock in about 15 seconds, but If I just get in and start it they don't. They unlock fine when the key is turned off. I thought it get the signal from the ignition on wire, so I checked it and it seems ok.  I have 12  volts when I turn the key to on and then around 10 while it's starting and 14 after it's running.  I don't understand why they lock if I  just turn the key to on and not when I start it?
Any ideas?
gcorrea
Silver - Posts: 436
Posted: September 16, 2006 at 6:27 PM / IP Logged
can you reprogram the alarm?
gcorrea
bigbadwhopper
Member - Posts: 6
Posted: September 16, 2006 at 6:35 PM / IP Logged
You can either program it to unlock when the keys goes on or not. and it is set to lock when the key goes on. Like I said, It works if you just turn the key on, but not when you just start it.
gethotwired
Posted: September 16, 2006 at 10:26 PM / IP Logged
THE VOLTAGE CHANGE SEEMS EXTREME TRY USING A RELAY TRIGGERED FROM THE IGN SOURCE TO SEND A SOLID VOLTAGE TO YOUR ALARMS IGN INPUT . ON THE RELAY 87 TO THE  CONSTANT 12V SOURCE (THE BATTERY IN A COLARADO), 85 TO GROUND, 86 TO THE IGN WIRE IN THE VEHICLE, 30 TO THE IGN INPUT ON THE ALARM.
hot wired autosound - nh
bigbadwhopper
Member - Posts: 6
Posted: September 17, 2006 at 11:16 AM / IP Logged
Thanks I will give that a Try. Let you know. might be a few days(busy at work)
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
