2007 Toyota Solara
vlepouce
Member - Posts: 22
Posted: September 21, 2006 at 6:00 AM / IP Logged
Anyone done an install on a 2007 Solara.  Buying one and will be installing 791xv.  Imobilizer required and which one to get.
caraudio904
Copper - Posts: 115
Posted: September 28, 2006 at 3:52 AM / IP Logged
I havent touched the 07 Solar but have done a couple 06. Wouldn't guess there is much difference, could be wrong but 06 Toyota Solar uses Dei 556UW Transponder. (Uses The Spare Key)
Southern Stylez
Jacksonville, FL 32218
bryantobando
Copper - Posts: 64
Posted: September 28, 2006 at 6:53 AM / IP Logged
This are the colors for 2004-2006 Solora. They can possibly be the same for the 2007. 556U Is the bypass used for these cars from 1999 and up.
12 VOLT CONSTANT
WHITE/ RED (+)
IGNITION SWITCH HARNESS
STARTERBLACK/ WHITE (+) IGNITION SWITCH HARNESS
STARTER 2BLACK / YELLOW (+)IGNITION SWITCH HARNESS
IGNITION 1RED / BLACK (+) or BLACK/ RED (+)IGNITION SWITCH HARNESS
IGNITION 2BLACK / YELLOW (+)IGNITION SWITCH HARNESS
IGNITION 3N/A
ACCESSORY /HEATER BLOWER 1BLUE/RED (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2N/A
KEYSENSEBLUE (-) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - )RED (-) @ HEADLIGHT SWITCH
PARKING LIGHTS ( + )GREEN (+) @ BOTTOM of FUSE BOX, 12-PIN Plug, Pin 8
POWER LOCKLIGHT GREEN or BLUE / YELLOW (TYPE B) See NOTE *1 @ 20-PIN PLUG, DRIVER KICK PANEL TYPE (B)
POWER UNLOCKBLUE (TYPE B) (Requires Double Pulse) See NOTE *1 @ 20-PIN PLUG, DRIVER KICK PANEL TYPE (B)
LOCK MOTOR WIREBLUE / YELLOW (+) or BLUE/RED (+) IN DRIVERS KICK PANEL, GRAY 11-PIN PLUG, PIN 3
DOOR TRIGGERSee NOTE *2 IN DRIVERS KICK PANEL and PASSENGER KICK PANEL
DOMELIGHT SUPERVISIONGREEN/ RED (-) @ RIGHT SIDE of FUSEBOX, 12-PIN PLUG, PIN 5
TRUNK RELEASEWHITE/ BLUE or WHITE (5-Wire) See NOTE *3 IN DRIVER KICK PANEL, 17-PIN PLUG, PIN 3
SLIDING POWER DOORN/A
HORNGREEN/ BLACK (-) @ STEERING COLUMN HARNESS
TACHBLACK/ ORANGE (-) @ ECM, See NOTE *4
WAIT TO START LIGHTN/A
BRAKEGREEN / WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM DISARMS with KEYSENSE wire, See NOTE *5 @ IGNITION SWITCH HARNESS
ANTI-THEFTTRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 when testing the LOCK and UNLOCK wires, test while turning the KEY in the DRIVERS DOOR KEY CYLINDER.
NOTE *2 the DRIVERS DOOR is a RED / GREEN (-) in the DRIVERS KICK PANEL, 17-PIN Plug, Pin 11, the PASSENGER DOOR is in the PASSENGER KICK, the wire is in a 12-PIN plug, Pin 7, on the Convertible it is in a 17pin plug, pin 17. When connecting to an ALARM SYSTEM, use both DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM
NOTE *3 this vehicle uses a 5-wire TRUNK/HATCH Release System that requires an extra Relay Part #775, to connect, See DIAGRAM
NOTE *4 the ECM (Engine Control Module) is located BEHIND the GLOVEBOX, on the 4-Cylinder, the tach wire is also located in the DATA LIK Connector, Pin 9, under the DRIVERS side of the DASH.
NOTE *5 THE KEYSENSE WIRE WILL DISARM THE VEHICLE WITHOUT UNLOCKING THE DOORS BY APPLYING A (-)NEGATIVE TO THIS WIRE DURING REMOTE STARTING.
