85 bmw 525i
Legrones
Copper - Posts: 75
Posted: October 03, 2006 at 8:32 PM / IP Logged
hello i am putting a r/s on a 85 bmw 525i but the owner only has one key is there a place becides the dealed to get a key or does howerd keys have the key for it ....but i will still need to get it cut dont think walmart will be able to crazey cut key...if u know of a non key buypass for the car help me out                                                     Thanks 12 volt world
Dale / Cory
shaggy12volt
Copper - Posts: 164
Posted: October 03, 2006 at 9:03 PM / IP Logged
r u sure its an 85' they didint use transponders back then i dont think if i remember right they didint make a 5 series till 1988
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
Legrones
Copper - Posts: 75
Posted: October 04, 2006 at 8:25 PM / IP Logged
im sorry its a 95 bmw 525i
Dale / Cory
shaggy12volt
Copper - Posts: 164
Posted: October 04, 2006 at 9:17 PM / IP Logged
WIRING INFORMATION - BMW / 5 SERIES / 1995 / Remote Start
[PRINT THIS PAGE]
85 bmw 525i -- posted image.
12volts red   +  steering column
Starter BLACK / YELLOW   +  steering column
Second Starter
Ignition green   +  steering column
Second Ignition purple   +  steering column
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock WHITE/ RED / yel dots   +  anti-theft plug
Notes: Anti-theft plug or module located under rear seat on passenger side, next to battery. Unlock may also be blue/BROWN / yel dots. Lock wires were available in previous years in drivers kick panel, but may be difficult to locate there for 94. These lock wires do not change state when the locks are operated, so they are difficult to test (they are intended for an optional remote-control keyless entry system). Be very sure of location before using these wires! Do not operate locks by remote when doors are open or deadbolted to prevent possible damage to servos.
Power Unlock blue/RED / yel dots   +  anti-theft plug
Lock Motor
Unlock Motor
Parking Lights+ gry/purple, gry/yel    at light switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger brn/gry, brn/blu, brn/ppl   -  anti-theft plug
Notes: These three are (in order) dr F, pass F, both R. Combine with diodes. The only combined wire is affected by domelight supervision and also shuts off after the door is open too long. Low-current domelight supervision is possible on any of these pinswitch wires.
Dome Supervision comes on with unlock
Trunk/Hatch Pin RED / white   +  harness to trunk
Notes: Also find trunk or rear hatch trigger at factory alarm plug by battery under passenger side rear seat.
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer black  AC  at diagnostic conn.
Notes: Round plug with screw-on cover at pass. shock tower or by fusebox on drivers side.
Wait to start
Brake Wire blue/red   +  brake pedal switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
EWS II
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
The Shagmaster
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
