Mazda Miata, Viper 791XV
speedcrazy
Posted: October 04, 2006 at 9:42 PM / IP Logged
Hi Everyone
My name is Leo, I'm new here
I have Mazda Miata with the viper 791xv alarm installed. i have noticed yesterday that when i engage the alarm, its not locking the doors for some reason. it used to do it before Mazda Miata, Viper 791XV -- posted image. did i pressed some i shouldn't or some wire got disconnected Mazda Miata, Viper 791XV -- posted image. is there any way to reset the system to the default setting or should i go to the alarm guy, let him take a look at it Mazda Miata, Viper 791XV -- posted image.
Best Regards
Leo
shaggy12volt
Copper - Posts: 164
Posted: October 04, 2006 at 10:48 PM / IP Logged
what year is your car
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
captainzab
Silver - Posts: 606
Posted: October 04, 2006 at 11:23 PM / IP Logged
01-05 miata
common problem is that the connection is bad at the resistor
i usually [buttend]- [resistor]- [buttend]
sometimes, the resistor wiggle alittle. not sure if this is how your installer did it.
take a look at the lock wire
Note: You Always Dont Get What You Pay For.
speedcrazy
Posted: October 04, 2006 at 11:34 PM / IP Logged
Hi
my car is 2000
and when i bought it i went to install that alarm
and they also installed the door lock thing, that locks the doors by itself.
Best Regards
Leo
captainzab
Silver - Posts: 606
Posted: October 04, 2006 at 11:37 PM / IP Logged
99-00 Miata
my guess is either the relay or the actuator
shaggy12volt
Copper - Posts: 164
Posted: October 04, 2006 at 11:46 PM / IP Logged
more than likely your resister has come disconected or loose.
if they were a good installer the should have soldered your conections and heat shrinked or tape them up a good you sould always have that resester soldered in line within the lock wire that way it wouldint come loose. if they used but conecters to conect the resister make them fix it and solder it
you must you relays with a 1000ohm resister on the lock wire they probly sold you a 451m for your keyless it could have a blown fuse also i take it it still unlocks but no lock the locking the doors by it self should be being done by the brain. oh does your car lock and unlock with the factory switches?
Power Lock purple  -  door lock control module
Notes: Lock is negative trigger thru a 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
The door lock control module is under the driver side dash towards the center of the instrument cluster.
Also found at the keyless control module behind the glove box, if equipped.
Power Unlock same as power lock wire
The Shagmaster
speedcrazy
Posted: October 05, 2006 at 11:22 AM / IP Logged
when i lock it by myself both doors locking automaticly.....
but it was doing it even before they installed the alarm.
Best Regards
Leo
speedcrazy
Posted: October 05, 2006 at 3:38 PM / IP Logged
ok
i went to the car got under the wheel
there was a bundle of wires going out from little black box
with a fuse i touched it a bit tight everything up
and its working now
should i look for something special in that bundel?
Best Regards
Leo
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
