2004 Toyota 4Runner, rear sliding glass
civic_tt
Member - Posts: 22
Posted: October 12, 2006 at 7:16 AM / IP Logged
Hello
I was wondering if anyone has hooked up the rear sliding glass on the 4Runner to a aftermarket system.  Also  the colors and/or procedure to to it that would be great.  I am installing a DEI Valet 552t.  The factory remote has a button and there is one inside the 4runner.  THANKS ERIK
Hymer
Silver - Posts: 695
Posted: October 12, 2006 at 8:46 AM / IP Logged
back glass up - purp/yell   Back glass down grey/red both are (-) trigger in the back door....
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Mike M2
Platinum - Posts: 2,652
Posted: October 12, 2006 at 3:52 PM / IP Logged
I find it easier to use two relays and power up the switch on the dash. Apply 12volts to black.blue on the switch and apply 12volts to the 1st igntion(BLACK/ red) wire in the ignition harness. For me it's easier than running wires into the hatch...
Mike M2
Tech Manager
CS Dealer Services
captainzab
Silver - Posts: 606
Posted: October 12, 2006 at 5:35 PM / IP Logged
should be found at the kick leading to rear
Note: You Always Dont Get What You Pay For.
Mike M2
Posted: October 12, 2006 at 8:41 PM / IP Logged
It's data link to the hatch control module. no wires to the rear...
Mike M2
Tech Manager
CS Dealer Services
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
