07 Suburban Door lock problem
csorb
Copper - Posts: 317
Posted: October 19, 2006 at 12:55 AM / IP Logged
Did a Remote Start/Alarm on this one. Used the xk01-gmdl6. After locking with the remote and then unlocking the doors unlock fine but then for some reason lock again on their own. If I hit unlock again, they stay unlocked. Anybody seen this?
Hymer
Silver - Posts: 695
Posted: October 19, 2006 at 9:55 AM / IP Logged
see what the vehicles lock options are programed for on the instrument cluster... what year burban?
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
csorb
Copper - Posts: 317
Posted: October 24, 2006 at 9:39 AM / IP Logged
Solved the problem. The brown wire into the xko1 was being pulsed during unlock. The removal of ground from this wire causes doors to lock. We just used a different ground out when running.
Hymer
Silver - Posts: 695
Posted: October 24, 2006 at 9:45 AM / IP Logged
Note to self "make sure not to pulse the ground out when running on dl modules".. Heh glad ya found it...
csorb
Copper - Posts: 317
Posted: October 29, 2006 at 3:38 PM / IP Logged
You have to connect the ground out when running, otherwise the factory alarm will go off when you remote start. Just make sure to have it on steady and not pulsed. Thanks
