help potiac transport
Welcome Guest :)
stevepara
Member -
Posted: January 22, 2003 at 7:54 AM / IP Logged
does anyone have a wiring diagram for 1998 pontiac transport montana extended, with keyless entry.
i need to install a security system with auto start
thank you in advance
steve
stevesnap@hotmail.com
10nesne1
Silver -
Posted: January 22, 2003 at 9:04 AM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | YELLOW | IGNITION SWITCH HARNESS * |
Ignition #1: | | | PINK | IGNITION SWITCH HARNESS |
Ignition #2: | | | WHITE | IGNITION SWITCH HARNESS (PCM) |
Ignition #3: | | | N/A | **** |
Accessory: | | | ORANGE | IGNITION SWITCH HARNESS (HEAT/AC) ** |
Brake Light: | | | WHITE (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | WHITE | AT POWERTRAIN CONTROL MODULE |
Parking Lights: | | | BROWN (+) | AT HEADLIGHT SWITCH |
Headlights: | | | YELLOW (+) | AT HEADLIGHT SWITCH |
OEM Alarm Disarm: | | | GREEN/ BLACK (-) | 16 PIN CONNECTOR IN DR. KICK PANEL |
OEM Alarm Arm: | | | N/A | SEE NOTES BELOW ** |
Diesel Glow Plug: | | | | |
Clutch Bypass Wire: | | | | |
Notes: | | ***Equippes with transponder anti-theft system - Use Universal Alarm Bypass Module following for "Transponders." ** See Installation Note #233 GM High Current Ignition if equipped with rear heat. ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness.' This wire will be used to control the anti-theft bypass module. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | RED & RED | IGNITION SWITCH HARNESS |
Starter Kill: | | | YELLOW | IGNITION SWITCH HARNESS * |
Ignition +12 Volts: | | | PINK | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | GRAY/BLACK (-) | AT BODY CONTROL MODULE *** |
OEM Horn: | | | BLACK (-) | STEERING COLUMN HARNESS |
Power Lock: | | | RED / BLACK (-) | AT BODY CONTROL MODULE **** |
Power Unlock: | | | WHITE | AT BODY CONTROL MODULE **** |
Trunk Release: | | | N/A | |
Alarm Input Wire: | | | GRAY/BLACK (-) | AT BODY CONTROL MODULE *** |
Notes: | | *** BCM Is Located To The Right Of The Glove Box. **** Negative Door Lock System. |
Monday, March 30, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
