avistart 4001-97villager
albl
Member - Posts: 11
Posted: January 24, 2003 at 8:01 AM / IP Logged
   i'm trying to install an avistart 4001 in a 97 merc villager with keyless entry the only wireing info i can find is for a non keyless entry car can any help me ?? I need wireing info for 97 merc villager with factory keyless entry.
         thanks
albl
10nesne1
Silver - Posts: 284
Posted: January 24, 2003 at 9:26 AM / IP Logged
Mercury
Villager
1996-1998
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED & WHITE/ BLUE
IGNITION SWITCH HARNESS *, **
Ignition  #1:
BROWN
Ignition #2:
RED / GREEN
Ignition  #3:
N/A
Accessory:
WHITE/ GREEN
Brake  Light:
YELLOW/BLACK (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
GREEN
AT IGNITION MODULE ON TOP OF ENGINE
Parking Lights:
PINK/BLUE OR PINK/WHITE (+)
DRIVER'S KICK PANEL
Headlights:
RED / BLACK & GRAY/RED (+)
AT HEADLIGHT SWITCH ***
OEM Alarm  Disarm:
RED / BLACK (-)
DRIVER'S KICK PANEL OR SECU MODULE ****
OEM Alarm  Arm:
RED (-)
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Engine Control Module Located Behind Glove Box. ** This Vehicle Is Equipped With Two Start Wires. Both Must Be Powered In Order For Vehicle To Start When Engine Is Cold; See Note #251 - Nissan Starter Wires Diagram.
Mercury
Villager
1996-1998
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ PURPLE
Starter  Kill:
RED & WHITE/ BLUE
Ignition  +12 Volts:
BROWN
Dome  Lights/Superv:
RED / BLACK (-)
IN 2-PIN CONNECTOR IN CENTER CONSOLE
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
GREEN / WHITE (-)
DRIVER'S KICK PANEL *****
Power  Unlock:
GREEN/ ORANGE (-)
Trunk  Release:
N/A
Alarm  Input Wire:
RED / BLACK (-)
Notes:
