DEI, Viper remote starts
angelars
Copper - Posts: 176
Posted: November 13, 2006 at 12:10 PM / IP Logged
We need to double check something on the Viper remote starts (all models). They have a orange wire which feeds the blower motor. Does that get its power from the RED / white? The RED / white just says "connection for high current outputs" in the instructions. Where is the best place to connect this (RED / white) wire to?
lsondubz
Copper - Posts: 193
Posted: November 13, 2006 at 3:07 PM / IP Logged
Connect it to the vehicles +12V ignition wire or the battery...
angelars
Copper - Posts: 176
Posted: November 27, 2006 at 12:22 PM / IP Logged
On the DEI remote starts there is an heavy orange wire that's marked as 'accessory output'. It powers the climate control system. We do a lot of Ford dealership installs and was wondering where it should correctly be hooked up. We were told to hook it up to the ignition switch along with a relay (as shown below) but that doesn't sound right. Shouldn't it go to the blower motor or something like that? Thanks.
DEI, Viper remote starts -- posted image.
mobilecustoms
Silver - Posts: 397
Posted: November 27, 2006 at 12:26 PM / IP Logged
thats if you need more than 1 acc wire hooked up
angelars
Copper - Posts: 176
Posted: November 27, 2006 at 12:55 PM / IP Logged
So where is the orange wire supposed to originally go?
kgerry
Platinum - Posts: 3,455
Posted: November 27, 2006 at 1:29 PM / IP Logged
it should go to whatever the acc wire in any particular vehicle is.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
angelars
Copper - Posts: 176
Posted: November 27, 2006 at 1:35 PM / IP Logged
Yes of course but at the ignition OR at the output (blower motor feed)?
jasondavis05
Copper - Posts: 55
Posted: November 28, 2006 at 2:36 AM / IP Logged
at the ignition
