2002 frontier r/s tach
slwilson6
Member - Posts: 6
Posted: November 16, 2006 at 4:13 PM / IP Logged
need help finding tach wire for r/s.  the pink/blue wire in the instrument cluster is reading 15v ac.  the pink/black in the instrument cluster is reading 0.8v ac.  the only wire i have found that actually adjusts when you tap the accelerator pedal is a PURPLE / white wire coming off the side of the distributor.  it reads 0.8v ac and when accelerator is tapped, it goes up to 1.9v ac.  i thought the tach wire was supposed to read between 1.5 to 6.  I am using the PURPLE / white wire and the starter only cranks for less than a second (not long enough to start the truck).  the r/s is a galaxy 5000 and does not have a program setting to adjust crank time, and because it is a manual transmission, it can not be run tachless.  any advice would be appreciated.
teeb
xtremej
Gold - Posts: 1,440
Posted: November 16, 2006 at 4:22 PM / IP Logged
According to directtech you should be looking for either pink/blue or black at the cluster or the ecm.
Mike M2
Platinum - Posts: 2,652
Use a fuel injector wire. Just pick a color that's not common to all the injectors.
Mike M2
Tech Manager
CS Dealer Services
KarTuneMan
Platinum - Posts: 7,056
Posted: November 18, 2006 at 5:05 AM / IP Logged
Find a lt.blue coming off the base of the distributor. It's next to a black wire.
slwilson6
Member - Posts: 6
Posted: November 20, 2006 at 8:16 AM / IP Logged
i see a small two wire harness coming off the base of the distributor with a blue wire and a black wire, separate from the main wire harness.  is that what you are referring to?
teeb
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
