toyota tacoma 2nd starter wire
mattstin
Posted: November 16, 2006 at 8:58 PM / IP Logged
I have searched about the 2nd started wire on the new 2006 Toyota Tacomas, and found out that you have to use a relay to power it up when remote starting. I was just wondering if anyone knew how to wire the relay up to the 2nd starter wire?
lsondubz
Copper - Posts: 193
Posted: November 16, 2006 at 9:52 PM / IP Logged
Most remote starts have a second starter output, What brand/model are you using?
cntrylvr79
Silver - Posts: 582
Posted: November 16, 2006 at 10:56 PM / IP Logged
Assuming your r/s has a negative second start output.
85 to second start output of rs.  86 to constant +12v. 87 to constant +12v. 30 to the second starter wire in the truck.  87a is unused.
Cause I'm So white and nerdy...
First Class Certi-fried installer
mattstin
Posted: November 16, 2006 at 11:49 PM / IP Logged
I searched about the 2nd starter wire on the 2006 Tacoma, and realized that I have to use a relay to power it up in remote start mode. Can someone tell me how to wire up the relay to the 2nd starter wire, and do I have to cut it like the starter wire?
mattstin
Posted: November 17, 2006 at 12:04 AM / IP Logged
Sorry for the repost. I am installing a viper remote start and keyless. I dont remember seeing a 2nd starter output coming from it, but maybe I overlooked. Assuming it does have a 2nd starter output, I will wire the relay like you told me. Thanks for the help!
KarTuneMan
Platinum - Posts: 7,056
Posted: November 18, 2006 at 5:03 AM / IP Logged
Viper.......?
Most of the DEI products have negative outputs for all of the main ign. connections.
Friday, May 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
