2002 chevy impala gm passlock
locdo
Posted: November 29, 2006 at 6:39 PM / IP Logged
Hi,
I have been searching for a bypass for a chevy impala 2002 for a remote starter.  I am not sure if certain alarm requires specific one for the bypass.  I told to one installer said that I can use dei 555L to bypass if I use code alarm ca 670.  I also found that their are other manufacture such as bypasskits.  Can some help me on this.  I also need a wiring harness for the radio since GM put the security on the radio not sure why.
thanks,
loc
mobilecustoms
Silver - Posts: 397
Posted: November 29, 2006 at 7:35 PM / IP Logged
check bypasskits.com- they are good
kgerry
Platinum - Posts: 3,455
Posted: November 30, 2006 at 1:00 PM / IP Logged
any of the following should work fine for you:
PLJX, GMBP, 556L, 555L, PLXR (replaced by PLJX)
you dont need to anything to the radio to put in a R/S unit......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Platinum - Posts: 12,488
Posted: November 30, 2006 at 11:05 PM / IP Logged
I use the iDatalink ADS-DL for data controlled door locks, trunk & Passlock II bypass.
