cougar 1999 4 pin pats wires colours
cibo55
Member - Posts: 9
Posted: December 11, 2006 at 8:33 PM / IP Logged
can samone help with the order of the wires on a cougar 1999 pats connector? they are 4 and the plug is broken, the wires are panding. i found the positions: 1-ignition, 2-ground, 3-TX, 4-RX, but i don't know theyr respective colours.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 11, 2006 at 10:20 PM / IP Logged
If you look at the MATING end of the plug, with the releas clip at the right, at the far right is IGN., then as you move left, GRND, then TX the at the far left is RX
cibo55
Member - Posts: 9
Posted: December 11, 2006 at 10:44 PM / IP Logged
thanks for your help kartuneman, i need the colours in order to replug them / the transponder plug on the car is broken and the wires are panding / i need to put them back and weld them on the pins plug / wires are grn/bk, bk/grn, why/lightgrn and gry/org  from my memory
thanks
