2000 Bonneville, 2 ignition wire colors?
slayder
Posted: December 16, 2006 at 11:12 PM / IP Logged
Hey,
the problem is the car won't remote start without the key being in the ON position. The R/S module clicks and I can hear the fuel pump go on but if the key is in the ignition only it doesn't start. It must be in the ON position. BTW 555G is installed as well. Passkey III.
I'm assuming to have the ignition wires wrong, according to the 3 diagrams the wire colors do not match.
Please don't post wiring diagrams from the different sites, I got those and 40% of the wire colors don't even match to the car wires.
If anybody worked on the Bonneville, please help. Or if you believe that the problem is somewhere else, let me know.
Twelvoltz
Platinum - Posts: 2,384
Posted: December 17, 2006 at 6:17 AM / IP Logged
Standard GM wiring, Ignitions are Pink and White, Accessories are Orange and Brown. The car will start and run with just the ignitions, if your bypass is installed and working properly but you will have service lights on the dash till you power at least the orange. Most GM do not require the brown for R/S.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
