Taplock, Asianwolf 2009 RS 2wy
karle
Member - Posts: 6
Posted: December 18, 2006 at 11:45 PM / IP Logged
Does anyone have any ideas about how to interface a Taplock unit (bought from Asianwolf) with a Asianwolf 2009 RS  2 way alarm system.  The door unlock interface with the alarm is very straight forward however I don't seem to have a (-) input on the brain to tap for disarming the alarm.  Any ideas?
THXTaplock, Asianwolf 2009 RS 2wy -- posted image.
Better to be lucky than good...
mando2155
Copper - Posts: 74
Posted: December 19, 2006 at 12:04 AM / IP Logged
  I dont think its meant to disarm the alarm.  If it did anyone that watched you tap on your window could do the same and let themselves in your car.  Besides if you locked your keys in the car the tap lock would let you in and you can just disarm with your remote, assuming its with your keys.
karle
Member - Posts: 6
Posted: December 19, 2006 at 12:34 PM / IP Logged
Mostly wanted it for surfing....since I cant take the remote in the water....guess I can just enable for passive arm when I surf... then I will get 10sec delay to get at the remote to disable.
Does anyone have any better ideas?  The tap lock "code" should be set up with four groups of taps...to make it next to impossible for someone to guess it...so Im not worried about that.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
