07 sierra remote start wiring
jacqueslacombe
Copper - Posts: 124
Posted: December 30, 2006 at 1:03 AM / IP Logged
HI  I need the wiring diagram for 07 sierra P-UP  to installed a remote starter  this truck is different from the 06 model         I notice it looks like the cadillac 2007 escalade
cocolaboy
KarTuneMan
Platinum - Posts: 7,056
Posted: December 30, 2006 at 10:10 AM / IP Logged
06, and 07 are the same.
Mike M2
Platinum - Posts: 2,652
Posted: December 30, 2006 at 11:08 AM / IP Logged
Not always. The 07 Sierra comes in two bodystyles. One is like the 06(and is called the Sierra Classic) and the other like the new Silverado. Use this diagram for an 07 Tahoe, most everything is the same....
12volts RED / white (2A)  +  ignition harness
Notes: For high current 12V, use RED / black (60A) and RED / black (60A) at the fuse box, black 40 pin plug, pins F1 and E3, or go to the battery.
Starter white  +  ign harn or BCM, lt. grn plug, pin 4
Notes: Starter is positive trigger thru a 1300 ohm resistor.
The BCM (Body Control Module) is to the left of the steering column.
See DirectFax document 1605 for remote start interface information.
For starter kill, use yellow/black (+) at the ECM, black 73 pin plug, pin 52. The ECM (Engine Control Module) is on the driver side fender, behind the headlight.
Second Starter N/A
Ignition pink  +  ign harn or BCM, lt. grn plg, pin 14
Notes: The BCM (Body Control Module) is to the left of the steering column.
Second Ignition N/A
Third Ignition N/A
Accessory brown or yellow  +  ign harn or BCM, lt. grn plg, pin 21
Second Accessory N/A
Keysense pink  +  ign harn or BCM, lt. grn plug, pin 2
Power Lock see DirectFax document 1607
Notes: To lock/unlock the driver door go to the driver door module or motor in the door and 5wi the tan (lock) and purple (unlock) motor wires.
To lock/unlock the passenger door go to the passenger door module or motor in the door and 5wi the tan (lock) and gray/black (unlock) motor wires.
To lock/unlock the rear doors use lt. blue (+) and white (-) at the BCM, gray plug, pins 7 and 9.
Power Unlock see power lock notes
Lock Motor gray  5wi fuse box, black 14 pin plug, pin B4
Unlock Motor purple  5wi DDM, brown 16 pin plug, pin 8
Notes: The DDM (Driver Door Module) is in the driver door.
Parking Lights+ brown (L), brown (R)  +  underhood fuse box, blk 30 pin plug
Parking Lights- lt. blue  -  switch or BCM, natural plug, pin 8
Hazards white  -  switch or BCM, lt. grn plug, pin 19
Turn Signal(L) lt. blue/wht (F), yel/blk (R)  +  BCM, brown plug, pins 4 and 1
Turn Signal(R) dk blu/wht (F), dk grn/wht (R) +  BCM, blk plg, pin 5; brn plg, pin 2
Reverse Light dk. blue  +  BCM, natural plug, pin 22
Door Trigger see notes  -  see notes
Notes: The LF door is gray/black at the DDM, brown 16 pin plug, pin 13. The RF door is tan/white or BLACK/ white at the PDM, brown 16 pin plug, pin 13. The LR door is lt. blue/black at the BCM, pink plug, pin 15. The RR door is lt. GREEN/ black at the BCM, pink plug, pin 14. Use all four wires and diode isolate each.
The PDM (Passenger Door Module) is in the passenger door.
Dome Supervision gray  +  BCM, natural plug, pin 5
Trunk/Hatch Pin pink/black  -  BCM, pink plug, pin 12
On vehicle with the power liftgate, the hatch pin wire is at the Liftgate Module in the passenger side rear quarter panel, black 16 pin plug, pin 11.
Hood Pin pink/black  -  pin sw or BCM, black plug, pin 17
Trunk/Hatch Release pink (glass), gray (gate)  -  BCM, pink plug, pins 24 and 13
Notes: Meter these wires while opening the liftglass or liftgate from the handle on the rear liftgate.
On vehicles with the power liftgate, use dk. GREEN / WHITE (-) at the switch in the overhead console.
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm lt. green  -  DDM, brown 16 pin plug, pin 4
Notes: Meter this wire while turning the key in the driver door key cylinder.
Disarm No Unlock with ignition and Passkey
Tachometer NOT pink, brown, or black  ac  any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. blue/white  +  switch or BCM, brown plug, pin 6
Notes: Meter this wire while pressing the brake pedal with the ignition on.
Parking Brake lt. blue  -  switch or BCM, brown plug, pin 16
Horn Trigger tan  -  switch or BCM, brown plug, pin 18
Memory Seat 1 orange  +  switch or DDM, blk 26 pin plg, pin 5
Notes: Memory seat 1 is positive trigger thru a 2260 ohm resistor. Memory seat 2 is positive trigger thru a 4260 ohm resistor.
Memory Seat 2 same as memory seat 1 wire  +
Memory Seat 3 N/A  +
07 sierra remote start wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III+
Part #: 556UW
Mike M2
Tech Manager
CS Dealer Services
