Viper 790 XV in 89 Civic
Boomn89
Posted: January 30, 2003 at 1:03 AM / IP Logged
I have been installing alarms for a couple of years now, but I've never done a remote start.  Everything has gone as planned except for the ACC 1 and ACC 2 wires.  I'm confused on these 2 wires.  On this Viper 790 XV, there is a PINK wire which is the " (+) Ignition Output  and there is an ORANGE wire which is (+) Accessory Output and there is a PINK/WHITE which is (+) Output to Second Ignition Circuit.  Here's where I'm confused, On my 1989 Honda Civic Hatchback, I have the following wires:
1)WHITE= constant  2)BLACK / YELLOW= True Ignition  3)BLACK/ WHITE= starter                                 BUT my problem is is that I have a YELLOW wire and a BLUE/WHITE wire that both throw a (+) before CRANKING only, basically in the run position.  I also have a WHITE/ RED throwing a (+) during the first click and second click only (ACC and RUN positions).  Which of these wires do I connect the PINK, ORANGE, and  PINK/WHITE wires too?  Don't I connect the PINK (+) Ignition Output to my BLACK / YELLOW which is my TRUE IGNITION wire?  Please Help.  Thank You.
Platinum - Posts: 12,488
Posted: January 30, 2003 at 7:58 AM / IP Logged
IGNITION|BLACK / YELLOW        |+  |ignition harness            ======= PINK on Viper
ACCESSORY|yellow              |+  |ignition harness          ======= ORANGE on Viper
SECOND ACCESSORY|blue/white  |+  |ignition harness====== PINK/WHITE on Viper
Boomn89
Posted: January 30, 2003 at 10:45 AM / IP Logged
thank you very much!!!!!!!!!!
Posted: January 30, 2003 at 12:20 PM / IP Logged
No problemo
