2007 Dodge Ram AutoPage 727
start25
Copper - Posts: 114
Posted: January 19, 2007 at 2:21 AM / IP Logged
I need HELP!!!
I was told that the wiring is the same for 2007 as 2006.
1.    I cant find 1st starter wire, its not in ignition harness, the diagram says drk, GREEN/ YELLOW but its not there, there's only like 4 wires blue with stripe, balck with stripe, purp/brwn, and pink/wht...is there really supose to be 2 starter wires if so...which one is the 1st one?  I found the PURPLE / BROWN  for 2nd starter/acc.
2.    Can find tech wire....
3.    And Parking light @ headlight switch, there is like 2 WHITE/ LIGHT GREEN  wires tested and doesnt seem like they're the right wires....
Please help, I need to get this done Friday.....
Twelvoltz
Platinum - Posts: 2,384
Posted: January 19, 2007 at 7:02 AM / IP Logged
Audiovox Lists:
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          LT.BLU/RED (2AMP)          (+)          IGNITION HARNESS
     Ignition 1          PINK/WHT          (+)          IGNITION HARNESS
     Starter 1          DK. GREEN/ YELLOW          (+)          IGNITION HARNESS
               OR STARTER BUTTON (SRT-10)
     All Door Trigger          MUST USE LATCH WIRES          (-)          BE SURE TO USE TWO DIODES TO ISOLATE
     Domelight Super          YELLOW/BLUE          (+)          DRIVERS A PILLAR
               CAN ALSO BE A YELLOW/ORANGE(+)
     LF Latch          VIOLET          (-)          IN HARNESS IN DRIVERS KICKPANEL
     RF Latch          VIOLET/WHITE          (-)          IN HARNESS IN PASSENGER KICKPANEL
     LR Latch          VIOLET/ORANGE          (-)          DRIVERS KICK
     RR Latch          VIOLET / YELLOW          (-)          PASSENGER KICK
     Alarm Disarm          FACTORY REMOTE ONLY
     Alarm Arm          FACTORY REMOTE ONLY
     Parking Lights          WHITE/ GREEN          (-)          AT VEHICLE LIGHT SWITCH
               PARKING LIGHTS ARE NEGATIVE TRIGGER THRU A 1130 OR 250 OHM RESISTOR. MUST USE A RELAY.
     Data Bus          DIAGNOSTIC PLUG UNDER DASH
     Convenience
     Headlights-Lo          WHITE/ GREEN          (-)          AT VEHICLE LIGHT SWITCH
               MUST USE A RELAY. HEADLIGHTS LIGHTS ARE NEGATIVE TRIGGER THRU A 660 OR330 OHM RESISTOR.
     Wipers-Lo          BROWN / WHT          (+)          WINDSHIELD WIPER MOTOR
     Wipers-Hi          BROWN / ORG          (+)          WINDSHIELD WIPER MOTOR
     Remote Start
     Ignition 2          PINK/GREEN          (+)          IGNITION SWITCH HARNESS
               THERE MAY BE NO IGNITION TWO
     Accessory 1          VIOLET/BROWN          (-)          SAME AS SECOND STARTER WIRE
               SEE SECOND STARTER MULTIPLEXED DODGE RAM TECH TIP
     Accessory 2          PINK / YELLOW          (+)          MAY BE NO SECOND ACCESSORY
               THIS WIRE WILL TURN ON THE ABS LIGHT IF NOT POWERED UP FOR REMOTE START
     Starter 2          VIOLET/BRN          (-)          IGNITION HARNESS
     Anti-Theft Type          DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Tachometer          TAN/RED, OR INJECTOR          (AC)          AT IGNITION COIL
               ON DIESEL MODELS THE TACH WIRE IS AT THE ECM ON THE LOWER DRIVER SIDE OF THE ENGINE, FRONT 60 PIN PLUG, PIN 24 OR AT THE CAMSHAFT POSITION SENSOR, LEFT OF THE ECM AT THE 3 PIN PLUG. ON SRT-10 MODELS THE TACH WIRE IS ON THE BLACK PLUG - PIN 18.
     Speed Sense          GREEN/ YELLOW          (AC)          PCM. IN A BLACK PLUG
               PIN 13. FOR SRT-10 MODELS, LOCATED IN A WHITE PLUG, PIN 27 OR OR DK.BLUE/ORANGE. DEISEL MODELS PIN 11 AT THE PCM.
     Brake Lights          WHITE/ TAN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          WHITE/ LT. GREEN          (+)          IN HARNESS, TOP OF DRIVER FENDER
     Horn          GREEN/ VIOLET          (-)          STEERING COLUMN HARNESS
               OR CLUSTER,GRAY PLUG,PIN 14
     Modules
     WIRE          LOCATION
     Module 1          PCM - LOCATED ON THE FIREWALL, PASSENGERS SIDE/ DIESEL MODELS IS LOCATED LOWER DRIVERS SIDE ENGINE COMPARTMENT
     Doorlocks/Windows
     Door Lock Circuit          ONE WIRE NEGATIVE SYSTEM          (-)          DRIVERS KICK
     Databus Wire          WHITE/ BLUE
     Power Unlock          VIOLET/GREEN          (-)          WITHOUT FACTORY SECURITY, DRIVERS KICK, 330 OHMS THRU A RELAY.
               WITH FACTORY SECURITY, LIGHT GREEN/ ORANGE IN DRIVER KICK, 2K OHMS FOR LOCK, DOUBLE PULSE 480 OHMS FOR UNLOCK, MUST USE RELAYS.
     PowerLock          VIOLET/GREEN          (-)          WITHOUT FACTORY SECURITY, DRIVERS KICK, 820 OHMS THRU A RELAY.
     Driver Mtr Unlock          TAN/LT.GREEN
     Driver Mtr Lock          LT.GREEN
     LF Window Up          ORANGE / LT. GREEN          (REV)          DRIVER KICK, DOOR HARNESS
               MOTOR WIRES MAY NOT REST AT GROUND
     LF Window Dn          ORANGE / WHT          (REV)          DRIVER KICK, DOOR HARNESS
     RF Window Up          ORANGE / TAN          (REV)          DRIVER KICK, DOOR HARNESS
     RF Window Dn          ORANGE / GRAY          (REV)          DRIVER KICK, DOOR HARNESS
     LR Window Up          ORANGE / WHITE          (REV)          DRIVER KICK, DOOR HARNESS
     LR Window Dn          ORANGE / GRAY          (REV)          DRIVER KICK, DOOR HARNESS
     RR Window Up          ORANGE / LT. BLU          (REV)          DRIVER KICK, DOOR HARNESS
     RR Window Dn          ORANGE / DK. BLU          (REV)          DRIVER KICK, DOOR HARNESS
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Platinum - Posts: 12,488
Posted: January 19, 2007 at 8:49 AM / IP Logged
If there's no DK GREEN/ YELLOW then you only have the VIOLET/BROWN wire to deal with. THis will be your primary starter wire. Wire up the proper relay bypass witht he proper resistance on the ACC & starter wire and the truck will start.
The tach wire ( DARK BLUE/GRAY ) is at the PCM on the passenger side firewall in a BLACK/ orange plug which is the second plug down from the top.
