04 Yukon, need good heated seat module
green6767
Copper - Posts: 209
Posted: January 21, 2007 at 4:34 PM / IP Logged
Well I did an 04 Yukon today using a GMDL-BP with an AstroStart 2205. All went well like always but when the customer came to pick up her vehicle...she now wants heated seats to turn on. I told her that the module I used does not take care of that and I will check into getting one that will. So...which one? I can get bypasskit products as I am a dealer, so I'm asking advice from people who have used them...and not from the people who want to sell me the most expensive one. Is there one that uses the same plug as the GMDL-BP, that way I can just swap em out, run a couple wires or whatever and be done? Also, is there ones that use the "detect the temp" and turn the seats on automatically or can I get one that I can hook up to an AUX. output? Or are there both options? Any help and advice is greatly appreciated! Thanks.
Dallas
Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 21, 2007 at 4:42 PM / IP Logged
Use the Astro IM-HDT-1
Activate BOTH seats with one aux. output Connect to the brown on the unit an output to pulse.
northern
Copper - Posts: 154
Posted: January 21, 2007 at 5:42 PM / IP Logged
I thought they discontinued the IM-HTD-1?
brcidd
Copper - Posts: 274
Posted: January 21, 2007 at 7:47 PM / IP Logged
I use the GM-SLs- they turn on the heated seats and mirrors automatically when temp is below freezing-- work great-- and inexpensive
Brcidd - Engineer That Does Remote Starter Installs on the side.
KarTuneMan
Posted: January 21, 2007 at 8:31 PM / IP Logged
the astro unit allows YOU to control the hot seats.....but, no mirrors
green6767
Copper - Posts: 209
Posted: January 22, 2007 at 1:13 AM / IP Logged
ok, I will check into that tomorrow. Thanks for the help!
northern
Copper - Posts: 154
Posted: January 22, 2007 at 10:49 AM / IP Logged
Kartuneman. The IM-HTD 1 is discountinued here. Does your distributor stil have them?
saskpuller
Copper - Posts: 144
Posted: January 28, 2007 at 9:54 AM / IP Logged
You could also use XK01 programmable unit. I believe it comes default for the Yukon.
green6767
Copper - Posts: 209
Posted: January 28, 2007 at 2:06 PM / IP Logged
yeah, after talking to my bypasskit rep, he gave me a full run through on the new programmable express kit series. the XK01 will work for the heated seats aswell as take care of the doors, security, and passlock along with some other goodies. I was impressed with the funcionality of those modules.
