2006 Saturn Ion, bypass
mlaurenza
Member - Posts: 33
Posted: January 22, 2007 at 11:38 AM / IP Logged
I recently did a 2006 Saturn Ion. I tried a XK-06 but had no sucess. I resorted back to the relay and resistor method. Has anyone had any luck with these? If so how did you wire it up. The instructions do not use the WHITE/ black wire in the ign. harness, but I cant figure out how it would work without it since it is required with the resistor method...
Hymer
Silver - Posts: 695
Posted: January 22, 2007 at 2:40 PM / IP Logged
Yeah, used a few and had no problems, dont connect the gowr brown until programed. it comes as a ion platform 1 out of the bag so no programing. Cut the resistor wire green to the key side, blu to the car side 12v, ign off the same harness red white and yellow I belive, orange is a starter in from the rs unit. and a ground... Never had a problem with one... Just those stupid chrysler products! Headach after headach!
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
customak47
Copper - Posts: 164
Posted: January 22, 2007 at 2:52 PM / IP Logged
Ive used the xko6 many times on the ion, the only problem i had was initial programming, just getting used to it. try it again, but have your relays prepped and ready if no success, but ive really had no problems...
My rifle is my friend...
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
