wiring for 2007 honda ridgeline, tips?
lsondubz
Copper - Posts: 193
Posted: January 26, 2007 at 11:13 AM / IP Logged
My neighbor just got an 07 Ridgeline and wants me to do a RS/Keyless on the side for him, are the wires the same as an 06? Any tips from you guys on this truck?
profuse007
Gold - Posts: 2,015
Posted: January 26, 2007 at 11:28 AM / IP Logged
Click here for diagram
Houston,TX
lsondubz
Copper - Posts: 193
Posted: February 04, 2007 at 11:54 AM / IP Logged
I read a few threads and it seems the only issue is running the wire into the door to disarm factory alarm...I am wondering if I am better off getting a bypass module that does everything via data...Anyone that has done these trucks have any input?
KarTuneMan
Platinum - Posts: 7,056
Posted: February 04, 2007 at 12:07 PM / IP Logged
I read, the CAN-SL2i is the one to get. Lockes transponder and defrost control. Not familier with the manufacturer, so I am unsure.
lsondubz
Copper - Posts: 193
Posted: February 04, 2007 at 12:13 PM / IP Logged
Well I was going to use the bypasskit 510 module, doorlocks,oem alarm via data, with a built in transponder bypass,I was wondering if pulsing the factory alarm wires will lock and unlock the doors as well? I can get the bypasskit module for about $60 but I am wondering if its worth compared to running the wires in the door?
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
