2006 grand cherokee laredo, alarm/rs
iceman5210
Posted: February 07, 2007 at 8:56 PM / IP Logged
I need the wiring diagram for this one , if anyone could help me out ill be really thankful. Im installing an alarm w remote start .
The Cat
cutter1122
Copper - Posts: 103
Posted: February 07, 2007 at 10:35 PM / IP Logged
12volts lt. blue/red (20A)  +  ignition harness
Starter pink/orange  +  ignition harness
Second Starter PURPLE / brown  -  ignition harness
Notes: The second starter wire is negative trigger thru a 150 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Ignition pink/lt. green  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory same as second starter wire  -  ignition harness
Notes: The accessory wire is negative trigger thru a 560 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Second Accessory N/A
Keysense N/A
Power Lock PURPLE / dk. green  -  driver door module in door
Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.
Can also use the trigger wires for the door lock relays found at the instrument cluster, conn. 2. Lock is lt. GREEN/ dk. green in pin 5. Driver door unlock is tan/lt. green in pin 6. Passenger door unlock is PURPLE / lt. green in pin 7.
Power Unlock same as power lock wire
Lock Motor lt. GREEN/ lt. blue  5wi plug above fuses, pin 36
Unlock Motor lt. GREEN/ dk. green  5wi plug above fuses, pin 35
Parking Lights+ do not use, relay rests at gnd
Parking Lights- (CAN data bus) (use hazards)
Hazards WHITE/ dk. blue to WHITE/ tan  -  SCM, 16 pin plug, pin 16
Notes: The SCM (Steering Column Module) is in the steering column.
Turn Signal(L) use hazards wire
Turn Signal(R) use hazards wire
Reverse Light WHITE/ lt. green  +  IPM , conn. 2, pin 2
Notes: The IPM (Integrated Power Module) is on the driver fender, behind the battery.
Door Trigger see notes  -  each kick or cluster, conn. 3
Notes: The LF door is purple in pin 6. The RF door is PURPLE / white in pin 7. The LR door is PURPLE / gray in pin 4. The RR door is purple / YELLOW in pin 5. Use all four wires and diode isolate each wire from each other and the control module. Refer to DirectFax 1076 for wiring information.
Dome Supervision yellow/orange  -  any light or cluster, conn 2, pin 12
Trunk/Hatch Pin pur/org and pur/brn (glass)  -  DKP or cluster, conn. 3, pins 3, 2
Hood Pin pink/lt. blue (export only)  -  pin sw. or FCM, 24 pin plug, pin 23
Notes: The FCM (Front Control Module) is on the driver fender, behind the battery.
Trunk/Hatch Release ORANGE / purple  -  DKP or cluster, conn. 3, pin 8
Notes: Meter this wire while opening the rear glass from the switch on the rear hatch.
The hatch release motor wire is ORANGE / gray (5wi) at the plug above the fuses, pin 25.
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT RED / tan or dk. grn/lt. grn ac  any ignition coil or fuel injector
Wait to start N/A
Brake Wire WHITE/ tan  +  brake pedal switch
Parking Brake dk. GREEN / WHITE  -  switch or cluster, conn. 1, pin 16
Horn Trigger dk. GREEN/ orange  +  horn or IPM, conn. 2, pin 35
Memory Seat 1 lt. GREEN/ orange  -  driver door module in door
Notes: The memory seats are negative trigger thru resistors. The resistor values are not known at this time. Cut the wire and meter it while pressing the memory seat buttons.
Memory Seat 2 same as memory seat 1 wire  -
Memory Seat 3 N/A  -
note: for doorlock; alarm; 2e starter; acc. wire; and transponder bypass use CHDL7-PK2
www.bypasskit.com
iceman5210
Posted: February 08, 2007 at 7:55 AM / IP Logged
 Than you so much I do preciated.
The Cat
