Delta pro-5005 combo
mfloresmx
Posted: February 03, 2003 at 10:22 PM / IP Logged
Hi there !!!!!!!
somebody know how to the passive alarm mode of the Delta pro-5005 combo ??????
and how to activate the dome light when the system is disarmed ??????
tks in advance.
phermann
Posted: April 08, 2003 at 5:04 PM / IP Logged
get in to programming mode ( ign on and hit button 3 times in 5 seconds) then after you hear the chrips hit the button once then hit to set passive arming hit button 2 on your oneway remote. turn off ign and it will be set.
Peter Hermann
Pro Electronic Hack.
phermann
Posted: April 08, 2003 at 5:09 PM / IP Logged
for dome light issue all i can say is use the BLACK/ white wire in the alarm harness this is a neg output to control a relay which you will have to set up to give you 12+ or ground depending on your cars light system.
Peter Hermann
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
