2007 cadillac cts wiring, 12v source
stevet
Member - Posts: 36
Posted: February 12, 2007 at 6:57 PM / IP Logged
HELP~ Neediing wiring info on a 2007 Cadillac CTS, from my other sources it says to capture 12v+ from the battery only is this true? Also how hard is it to gain access to the ignition wiring harness from the left side of the dash?
Thanks for any info need it tonight!
KarTuneMan
Platinum - Posts: 7,056
Posted: February 13, 2007 at 11:41 AM / IP Logged
Find a feed (12v source) into the fuse box. You are correct, you cannot use the ignition harness. It's the battery of what I suggested!      Sucks.....
