98 blazer and autopage RS-750lsd
drewbu
Member - Posts: 9
Posted: February 07, 2003 at 2:39 PM / IP Logged
I really need some help ... i got the wiring dioghram ... but i don't know where to look for the wires ...
I don't even know where to start ..
can some one give me REALY detailed info ... like step by step
and where should i mount the main unit of the alarm under the hook or inside?
plz help... thx
Platinum - Posts: 12,488
Posted: February 07, 2003 at 2:59 PM / IP Logged
All the wires for the starter is located at the key cylinder and the other wires for keyless entry are located at the BCM. Here is a wiring diagram with the locations of the wires you will need to hook up the system:
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |brown plug at BCM *1        |
|     POWER UNLOCK|white               |+  |brown plug at BCM *1        |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |lt. blue plug at BCM *1     |
| PARKING LIGHTS -|white *4            |   |lt. blue plug at BCM *1     |
|       HEADLIGHTS|PURPLE / white        |-  |purple plug at BCM *1       |
|     DOOR TRIGGER|*2                  |-  |BCM *1                      |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|pink/black          |-  |lt. blue plug at BCM *1     |
|TRNK/HTCH RELEASE|black               |-  |purple plug at BCM *1       |
|       TACHOMETER|white               |   |PCM *3                      |
|       BRAKE WIRE|white               |+  |steering column             |
|     HORN TRIGGER|black               |-  |steering column             |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L.  *1 The BCM is located to the right of the accelerator pedal below the radio.  The plugs on the BCM face towards the drivers side.   *2 Use tan for the drivers door located in pin B4 of the purple plug, orange for the passenger door located in pin B2 of the purple plug, and dk. blue/white for the rear doors and rear hatch located in pin B11 of the lt. blue plug, must diode isolate these wires.  *3 The PCM is located on the passenger fender. On the 2.2L the wire is in a black 80 pin plug pin 10, and on the 4.3L the wire is in a red 32 pin plug pin 20.  *4 This wire will not test when using the headlight switch. This wire is triggered by the DRL system. To meter the wire, start the car with the parking brake set, when the brake is released this wire will go to ground.
Mount the CPU in behind the glove box or the radio. Try not to use the traditional spot of above the driver kick panel.
drewbu
Member - Posts: 9
Posted: February 09, 2003 at 5:57 PM / IP Logged
tnx but ... ineed more than that..
Most of the wires are
not where and not the same color ...
and i got unlokin doors to work but for some resons my batery goes dead after couple of minutes of testing it.....
need more help.. plzzz
