Help with Hornet 700t alarm system...
Kwazyace
Member - Posts: 12
Posted: February 09, 2003 at 6:07 PM / IP Logged
Vehicle: 2002 GMC Sonoma
Hi all- I recently installed a hornet 700t alarm systems that is supposed to integrate with the factory keyless entry system. But the system will only arm when I have the parking lights on- and it seems to disarm when I shut the parking lights off. When I lock or unlock the doors with the factory remote the alarm does not respond at all- unless the parking lights or headlight are on!! I am certain I have the parking light wire correct because I am getting 12 volts with the meter on the blue wire at the headlight switch when I put the parking lights on- I get no variation in voltage when turning the dimmer, and it drops voltage when I turn the parking lights off so it should be the correct one. The remote also seems to work fine when I am in the options mode for the alarm (it responds to all options) so what else could it be? I am wondering if it has anything to do with the GM automatic headlights system? Thanks in advance...
Chris Luongo
Platinum - Posts: 3,746
Posted: February 09, 2003 at 8:00 PM / IP Logged
Can you still get into programming mode even with the parking lights off?
The only thing I can think of is to refer back to the install manual and make sure your power and parking lights wires are done correctly------parking light output is white, constant power input is red------if you accidentally switched the two, the alarm would only work with the lights on.
camino
Copper - Posts: 54
Posted: February 26, 2003 at 5:24 PM / IP Logged
another thing is,maybe the wires on the connector are in the worng position,is wired but that hapend to me before,check that.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
