1999 accord ex defroster wire?
peterubers
Silver - Posts: 706
Posted: April 29, 2007 at 2:54 PM / IP Logged
I am trying to avoid taking the center console apart to get behind the actual defroster button --> looking for the heavy gauge wire in/around the lower dash fusebox that requires a latched positive -- KarTuneMan? Anyone?  Thanks
The search function is your friend.
peterubers
Silver - Posts: 706
Posted: April 29, 2007 at 3:03 PM / IP Logged
..Also (second question):
I want to do an alarm defeat w/o unlock/lock --> so I want to use the blue wire at the driver's power window switch (requires neg. (-)) --> however, does this blue wire require a negative pulse or a latched negative signal?  Thanks
peterubers
Silver - Posts: 706
Posted: May 01, 2007 at 9:44 AM / IP Logged
anyone?
peterubers
Silver - Posts: 706
Posted: May 01, 2007 at 12:34 PM / IP Logged
Figured it out -- thanks the the service manual obtained at hondatech.info/downloads/accord
BROWN / YELLOW wire at green plug behind HVAC unit --> needs to see ground (-).
Thanks for playing.
peterubers
Silver - Posts: 706
Posted: May 02, 2007 at 12:51 AM / IP Logged
Oh, and that blue wire needs to see a pulsed negative signal --> and you cannot catch it closer to the lower dash or on the interior b/c the superlocking unit (which receives the blue wire from the driver's key lock cylinder) that is resident in the driver's door sends a binary code to the Multiplex unit (body ecu, basically) which then de-activates the factory alarm.
Word.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
