wiring 2007 suzuki sx4
Jacj
Posted: May 01, 2007 at 1:12 AM / IP Logged
Anyone done a 2007 Suzuki SX4? I need the wiring diagram.
Twelvoltz
Platinum - Posts: 2,384
Posted: May 01, 2007 at 11:35 AM / IP Logged
Here is what Audiovox lists:
          #510980: 2007 SUZUKI SX4 4DR
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Please select another category
     Security
     Battery          WHITE/ BLUE          (+)          IGNITION HARNESS
     Ignition 1          GREEN          (+)          IGNITION HARNESS
     Starter 1          GREEN / WHITE          (+)          IGNITION HARNESS
     All Door Trigger          USE LATCH WIRES          (-)          DRIVERS KICK PANEL
     LF Latch          BLACK/ RED          (-)          DRIVERS KICK PANEL
     RF Latch          BLUE/BLACK          (-)          DRIVERS KICK PANEL
               THIS WIRE CATCHES PASSENGER DOOR AND BOTH REAR DOORS.
     Low Crr Pk Lights          RED / YELLOW          (-)          AT MODULE BELOW STEERING COLUMN
     Convenience
     Remote Start
     Accessory 1          YELLOW          (+)          IGNITION HARNESS
     Low Crr. Pk Lights          RED / YELLOW          (-)          AT MODULE BELOW STEERING COLUMN
     Brake Lights          GREEN / WHITE          (+)          DRIVERS KICK
     Modules
     WIRE          LOCATION
     Module 1          BCM IS LOCATED BELOW THE STEERING COLUMN
     Doorlocks/Windows
     Power Unlock          GREY/RED          (+)          DRIVERS KICK PANEL
     PowerLock          GREY/WHITE          (+)          DRIVERS KICK PANEL
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
