1997 monte carlo locking system?
cavyinthegarage
Copper - Posts: 52
Posted: February 10, 2003 at 9:35 PM / IP Logged
Can someone tell me what kind of a locking system this is?  Thanks...
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |drivers kick panel *2       |
|     POWER UNLOCK|white               |+  |drivers kick panel *2       |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |DKP or light switch *3      |
|       HEADLIGHTS|yellow              |+  |at light switch *3          |
|     DOOR TRIGGER|dk. blue            |-  |drivers kick panel *2       |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|RED / black           |-  |at light in trunk           |
|TRNK/HTCH RELEASE|blk/wht or black    |+  |at release switch           |
|       TACHOMETER|PURPLE / white        |   |ign coil or ECM underhood *1|
|      SPEED SENSE|green               |4  |ECM under hood *1           |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|pink                |+  |steering column             |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |LF motor in drivers door    |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers kick panel          |
|  LR WINDOW UP/DN|dk. green - purple  |A  |drivers kick panel          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers kick panel          |
Notes:
*1 Find ECM on passenger side under hood behind headlight and under fuse panel.   *2 Located in harness behind the carpet in the driver's kick panel. Relays in upper corner of passenger side kick panel behind glovebox.  *3 The light switch is easily accessed by pulling the gauges
Player69
Silver - Posts: 504
Posted: February 10, 2003 at 9:41 PM / IP Logged
cavyinthegarage
Copper - Posts: 52
Posted: February 11, 2003 at 10:59 PM / IP Logged
THANKS FOR THE HELP!!
