05 silverado bypass module
$$hustler$$
Posted: May 04, 2007 at 5:18 PM / IP Logged
I used a 457gw for this vehicle, tha remote start works but tha door locks do not. what is tha best module to use on this vehicle or am i just not doing it right?
enice
Silver - Posts: 857
Posted: May 04, 2007 at 6:21 PM / IP Logged
http://bypasskits.fortinautoradio.com/en/products/bypass_kits/gm-sl2i/?year=2005&make=1&model=659  This link will show you the GM-SL2i.  It will do the bypass and ALOT MORE!!!!!_If your interested you can find a compustar dealer or crimestopper dealer.
another-kelly
Silver - Posts: 618
Posted: May 05, 2007 at 9:49 PM / IP Logged
must not be using it right cause it should do the locks (when installed properly)
advancedautosec
Member - Posts: 46
Posted: May 08, 2007 at 7:12 PM / IP Logged
you dont need the bypass for the locks if its a base model silverado. you can try lt.blue(lock)pin B5 and white(unlock) pin B10 of the BCM in a lt. blue plug.
another-kelly
Silver - Posts: 618
Posted: May 09, 2007 at 6:30 AM / IP Logged
i had a base model silverado in bout 2 months ago that i had hoped for this but no such luck. used a 457g
dswift
Copper - Posts: 396
Posted: May 09, 2007 at 6:29 PM / IP Logged
then i would get your locks seperatly or use a gmsl2i. word
"dont ground out!"
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
