need 04 grand cherokee radio wiring info
sik soundz
Posted: June 04, 2007 at 6:54 PM / IP Logged
i just bought a 04 grand cherokee and the radio info is not in the wiring diagrams any help would be great also if i replace the factory hu will i lose the function of the factory amp ? ty
KarTuneMan
Platinum - Posts: 7,056
Posted: June 04, 2007 at 7:20 PM / IP Logged
+12V DC Battery(Constant)RED / white Also powers amplifier 25 amp J/B behind left side of dash
Switched AccessoryWHITE/ red Pin 2 30 10 amp J/B behind left side of dash
Ground Black Pins 11 & 22
Power Antenna BROWN / white Changes to BLACK/ white
Remote Turn On(output) BROWN / white Pin 13
Illumination Orange Pin 3
Steering Wheel Control Wire RED / yellow & RED / black
Left Front + Dk.GREEN/ orange Pin 10 Line level output
Left Front - BROWN / red Pin 9 Line level output
Right Front + Violet Pin 7 Line level output
Right Front - Dk.blue/pink Pin 8 Line level output
Left Rear + WHITE/ dk.green Pin 18 Line level output
Left Rear - Dk.GREEN / WHITE Pin 19 Line level output
Right Rear + Dk.blue/white Pin 21 Line level output
Right Rear - Dk.blue/orange Pin 20 Line level output
need 04 grand cherokee radio wiring info -- posted image. AMPLIFIER OUTPUTS
Wire FunctionColorNoteFuse #SizeLocation
12V DC BatteryRED / white Pins 2 & 10 25 amp J/B behind left side of dash
Remote Turn On (input) BROWN / white Pin 13
Left Front Mid + Lt.GREEN/ red Pin 8
Left Front Mid - Lt.GREEN/ dk.green Pin 3
Left Front Tweeter + Yellow/red Pin 4
Left Front Tweeter - Yellow/black Pin 11
Right Front Mid + Lt.blue/red Pin 10
Right Front Mid - Lt.blue/black Pin 9
Right Front Tweeter + ORANGE / red Pin 12
Right Front Tweeter - ORANGE / grey Pin 5
Left Rear Mid + Dk.GREEN / WHITE Pin 6
Left Rear Mid - WHITE/ dk.green Pin 7
Right Rear Mid + WHITE/ violet Pin 1
Right Rear Mid - Tan/dk.green Pin 2
need 04 grand cherokee radio wiring info -- posted image. AT SPEAKERS
Right Front Tweeter - ORANGE / black
Left Rear Mid + Tan/dk.green
Left Rear Mid - WHITE/ violet
need 04 grand cherokee radio wiring info -- posted image.  Available Notes
Notes
The amplifier is located under passenger side rear seat cushion.
sik soundz
Posted: June 04, 2007 at 7:49 PM / IP Logged
wow fas reply thanks for the info
