remote start for Aladdin
podrido
Posted: February 14, 2003 at 12:33 PM / IP Logged
what's up velocity
i hooked up all the wires that seem to be required for a 95 eagle talon esi, the alarm is an Aladdin a2000. Everthing is programmed and working, i remote shows that the car is on but the car isn't. I tried hooking up the start assist wire to the clutch bypass but i couldn't so i just disconnected the harness for the clutch and the car normally starts without pressing on the clutch. Also , i got a wiring diagram from the net and it said that the ign2 wire is the heater/ac , so i never used a relay for a second ignition as i just assumed that it is the Heater wire.
 i've been trying to figure out the problem for a while now, the car is a mess with wires hanging around everywhere....can you please reply A.S.A.P
Platinum - Posts: 12,488
Posted: February 14, 2003 at 12:54 PM / IP Logged
Did you go through the proper exit procedures as described on page 11 of the color manual ? If you did do this, try sitting in the car while you go through the manual start setup & this time, depress the clutch while remote starting & see if the car starts. If it does, then you have to hook up the clutch bypass to the Aladdin a-2000. If it still doesn't start, then you have a wiring problem that you will need to trace back. Here is a wiring diagram that I have for this vehicle. Please check this and re-check the wires with a DMM to ensure that you have the correct wires. DO NOT ASSUME THE COLORS ARE RIGHT, You may have tapped into a similiar colored wire by accident and the system is not responding the way it should.
podrido
Posted: February 15, 2003 at 11:12 AM / IP Logged
i tried sitting in the car and pressing the clutch ....and the only response was the lights on the dash. I also checked every wire that i hooked up with the DMM and all the circuits were verified. Moreover i never got the wiring diagram.
Posted: February 15, 2003 at 11:23 AM / IP Logged
Verify all your wiring connections to this diagram: Your door switch has to be hooked up as well.
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ red           |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|blue/black          |+  |ignition harness            |
|       POWER LOCK|RED / blue            |-  |*1                          |
|     POWER UNLOCK|BROWN / red           |-  |*1                          |
|       LOCK MOTOR|blue/black          |   |drivers door harness        |
|     UNLOCK MOTOR|blue/red            |   |drivers door harness        |
|    DISARM DEFEAT|blue/red            |   |passengers door harness     |
| PARKING LIGHTS +|GREEN / WHITE         |   |in drivers kick             |
| PARKING LIGHTS -|GREEN / WHITE   22 awg|   |steering column *2          |
|       HEADLIGHTS|red                 |-  |steering column             |
|     DOOR TRIGGER|RED / green           |-  |in drivers kick *3          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|RED / green           |-  |driver kick panel *3        |
|         HOOD PIN|blue/black          |-  |fuse box                    |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|GREEN / WHITE         |-  |drivers door harness        |
|       TACHOMETER|white               |   |instument cluster or PCM *4 |
|      SPEED SENSE|yellow/white        |   |data link connector *5      |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|GREEN/ black         |-  |steering column             |
|           WIPERS|blu/org(L),blu/blk(H|+  |steering column             |
|  LF WINDOW UP/DN|grn/red - grn/black |A  |in drivers door             |
|  RF WINDOW UP/DN|brn/yel - grn / YELLOW|A  |in drivers door or dkp      |
Notes:
*1 Located behind the glove box in a harness. To unlock only the drivers door on models with keyless entry. Use BROWN / blue negative (-) trigger at the relays behind the radio.  *2 Found in a gray 20-pin connector.  *3 To avoid the dome light delay use RED / white (-) at the door open indicator at the instrument cluster. The RED / white will also catch the rear hatch.  *4 The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor.    *5 The data link connector is under the driver side dash.
