2008 dodge avenger wiring
Welcome Guest :)
brudnic
Member -
Posted: July 12, 2007 at 6:59 PM / IP Logged
Looking for any wiring colors for rs in 08 avenger
KarTuneMan
Platinum -
Posted: July 12, 2007 at 10:54 PM / IP Logged
You will see this Sebring is the same as the Avenger!
| PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
| | | This vehicle is equipped with a TRANSPONDER passive anti-theft system. A keyless bypass module may be available for remote start installations, contact your supplier to find out. If one of these modules is not available to you, refer to our transponder bypass diagram. |
| 12 VOLTS | Red | At junction in driver's kickpanel | + |
| IGNITION | Pink | Ignition switch harness | + |
| ACCESSORY | Violet/brown | Ignition switch harness | mux |
| STARTER | Violet/brown | Ignition switch harness | mux |
| LOCK | Lt.geren/violet | In driver's kickpanel | - |
| | | Ground through a 330-ohm resistor to lock the doors |
| UNLOCK | Lt.geren/violet | In driver's kickpanel | - |
| | | Ground through a 100-ohm resistor to unlock the doors. |
| DOORPIN | SEE NOTES | | |
| | | LF is Violet, RF is Violet/white, LR is Violet/gray and RR is Violet / YELLOW. All 4 wires are located on the brown plug behind the instrument cluster. You can also use a Yellow/white (domelight output)which catches all doors (with delay) in the same location. |
| HOODPIN | Violet/blue | At pinswitch under hood | - |
| TRUNK PIN | Violet/orange | On brown plug behind instrument cluster or in DKP | - |
| TRUNK RELEASE | GREEN / WHITE | At trunk release switch | - |
| FACTORY ARM | Through OEM remote only | | |
| FACTORY DISARM | Through OEM remote only | | |
| BRAKESWITCH | GREEN / WHITE | At switch or in driver's kickpanel | + |
| PARKLIGHTS | WHITE/ violet | In driver's kickpanel | + |
| HAND BRAKE | Dk.GREEN / WHITE | On brown plug behind instrument cluster or switch | - |
| HORN | GREEN/ violet | At steering column | - |
| DRIVER WINDOW UP | ORANGE / green | At switch in driver's door | Rev Pol |
| DRIVER WINDOW DOWN | ORANGE / white | At switch in driver's door | Rev Pol |
| PASSENGER WINDOW UP | ORANGE / tan | In driver's kickpanel | Rev Pol |
| PASSENGER WINDOW DOWN | Orange / YELLOW | In driver's kickpanel | Rev Pol |
| LEFT REAR WINDOW UP | ORANGE / white | In driver's kickpanel | Rev Pol |
| LEFT REAR WINDOW DOWN | ORANGE / gray | In driver's kickpanel | Rev Pol |
| RIGHT REAR WINDOW UP | ORANGE / green | In driver's kickpanel | Rev Pol |
| RIGHT REAR WINDOW DOWN | ORANGE / blue | In driver's kickpanel | Rev Pol |
| REVERSE LIGHTS | WHITE/ green | Under driver's side running board | + |
| VSS WIRE | GREEN/ brown | At PCM under hood | AC |
| KEY MUX | Violet/brown | Ignition switch harness | mux |
brudnic
Member -
Posted: July 14, 2007 at 8:58 AM / IP Logged
Thank you. I checked audiovox and directechs for the info and could not get it. I appreciate it.
Tuesday, April 7, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
