2002 f250 diesel
lemonaters
Posted: February 15, 2003 at 8:20 PM / IP Logged
would like to knoe if this truck has a 5 wire alternating 12 volts system or a 4 wire reverse door lock system also would like to know wire color and locations.I tried the 5 wire system with the pink / YELLOW and pink/green on the door jam like instructions said and when manually activete relays nothing(expect smoke coming from door panel) thank in advance any help will be a liife saver
Haku
Copper - Posts: 204
Posted: February 15, 2003 at 10:29 PM / IP Logged
Hope this helps.
*1 Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM. On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to 'wake-up' the system refer to directfax document #1094.
Hak
Siemens Autostart
lemonaters
Posted: February 15, 2003 at 10:38 PM / IP Logged
thank you do u hook up 5 wire reverse polaruty the same way u hook up 4 wire circuit with four relays?????????
Haku
Copper - Posts: 204
Posted: February 15, 2003 at 11:07 PM / IP Logged
https://www.the12volt.com/doorlocks/page3.asp#5w
That link will show you how to do it with relays.
If you still need information, I will send you a better diagram.  Email me your address.   ip3@centurytel.net
Hak
Siemens Autostart
