2005 dodge ram, alarm/remote start
wire4veins
Copper - Posts: 97
Posted: July 27, 2007 at 3:00 AM / IP Logged
I have done four of these 2005 Dodge rams installing a Alarm/Start combo in each one. I used the Autopage RS-727s and one RS-1000OLED on them. I am now on my fifth one and am having a false due to the door triggers(Icon on the remote appears roughly 2-3 minutes after arming). I have checked the triggers and the diodes for correst position and everything checks out good. Delayed dome light ignore is programmed also. Has anyone had any trouble with one of these Dodges. I obviously have done all five now the same four with no problems which is what really gets me! I have seen a few posts on here for single wire triggers which I would like to try if anyone knows color/location. Thanks in advance.
Wires I am using:
Door Trigger      -       see notes
Notes: The LF door is gray/black at the DDM, brown 16 pin plug, pin 13. The RF door is tan/white or BLACK/ white at the PDM, brown 16 pin plug, pin 13. The LR door is lt. blue/black at the BCM, pink plug, pin 15. The RR door is lt. GREEN/ black at the BCM, pink plug, pin 14. Use all four wires and diode isolate each.
"D" - Owner/MECP Master Installer
Precision Audio - Utah
"You might find it Cheaper...but you won't find it better."
KarTuneMan
Platinum - Posts: 7,056
Posted: July 27, 2007 at 8:33 AM / IP Logged
I have read, and understand that your on your 5th identical unit. But have you considered goin into the kicks for the door pins? Left side in the same connector as the lock wires. The right side in a white connector. Like I said, maybe check this and try it. These can also be found behind the guage cluster. in plug C1
LF is Purple
RF is PURPLE / grey
RF is PURPLE / white
RR is purple / YELLOW
Moderator - Posts: 12,488
Posted: July 27, 2007 at 9:26 AM / IP Logged
For the Dodge door triggers I would also use a relay to isolate the triggers from each other along with the diodes.
wire4veins
Copper - Posts: 97
Posted: July 29, 2007 at 11:35 AM / IP Logged
I have all of those wire connected in the kick panels with diodes. I disconnected one of the trigger wires and with a DVM on it it shows 12v about a minute after the door is closed which is about when it triggers the alarm.
wire4veins
"D"
Precision Autosound - Owner
enice
Silver - Posts: 857
Posted: July 29, 2007 at 11:42 AM / IP Logged
Looks like the computer turns off causing a false alarm.  What you may have to do is put a diode in between the actual door triggers and then connect your door trigger input wires on the side thats after the diode not before the diode. Use DOC 1076.  Its quite common on fords with the GEM but may also apply to other platforms.
Posted: July 31, 2007 at 3:21 AM / IP Logged
enice try my favourite VW's the trunk light, also Fords with GEM box.
swerks
Copper - Posts: 224
Posted: July 31, 2007 at 10:53 AM / IP Logged
have u cut the pin wires and placed a diode in each one cathode towards the door?
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
wire4veins
Copper - Posts: 97
Posted: August 02, 2007 at 10:24 PM / IP Logged
Thanks for all your advice. One of the diodes was bad apon testing it.
wire4veins
"D"
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
