diodes
minhbach
Copper - Posts: 93
Posted: August 02, 2007 at 2:07 AM / IP Logged
I got some diodes from my work place. I am not sure if it is the right blocking diodes for door trigger.  The reading on it is 1N4004 T336 and the other one is zp 1N4004 9014(Motorola brand) for this one. Could anyone help me to read those last number, and tell me what is represented as well as the diode has a zp letters in the front. Will that be okie thehe pse for door trigger. I can see the part number are the same.
Posted: August 02, 2007 at 1:09 PM / IP Logged
They are the same, only important part is 1N4004. The last 4 is the reverse voltage AKA PIV you could apply if I remember these are more than adequate with a 1amp power handling. P.S. The other writing is simply manufacturers' batch numbers.
Thursday, January 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
