88 dodge shadow power locks.
raccoon
Posted: August 12, 2007 at 3:58 PM / IP Logged
Ive just installed a remote starter some cheaper one from Canadian tire.
http://www.autostart.ca/prostart/prod-en_CT-3200.php
anyway I got the remote starter working just perfect, now I want to use the remote power door lock option. the unit can send out negative pluses on 2 separate wires for lock and unlock.
heres a diagram of the cars locking system, I cant figure out what kind of relay setup im going to need. 2 wire 3 wire power system, vacuum system im just more confused now.
88 dodge shadow power locks. -- posted image.
point me in the right direction :)
Paul
raccoon
oh and the car is a 2 door while the diagram is for a 4 door car, but that shouldn't change much.
captainzab
Silver - Posts: 606
Posted: August 12, 2007 at 4:38 PM / IP Logged
1987-1990 Dodge Shadow
POWER LOCK        ORANGE (TYPE C)        IN DRIVERS KICK PANEL
POWER UNLOCK       PINK (TYPE C)       IN DRIVERS KICK PANEL
Type C is reversing polarity
https://www.the12volt.com/getimage/5wap.gif
Note: You Always Dont Get What You Pay For.
fkelsey
Copper - Posts: 94
Posted: August 12, 2007 at 4:46 PM / IP Logged
According to my diagram in your car lock is lock is orange and unlock is pink both are 5 wire and in your driver kick panel. I am assuming this is right it has been a long time since I have even seen a Dodge Shadow. Wire your relays like this, cut your lock and unlock wires in two. Lock relay 85 negative trigger from your RS, 86 and 87 12 volts, 87a switch side of lock wire, 30 motor side of lock wire. Do the same for your unlock relay.
raccoon
Posted: August 12, 2007 at 7:39 PM / IP Logged
lol yea not too many left its just a project car, Ill wire it up tomorrow with some relays and let you know how it went, thanks.
I remember seeing them when they were new and wanted one sooo bad.
fkelsey
Copper - Posts: 94
Posted: August 12, 2007 at 7:48 PM / IP Logged
88 dodge shadow power locks. -- posted image. 88 dodge shadow power locks. -- posted image. To each his own lol. When you finish pumpin your ride let us see how it turned out. Thanks for the pics that really took me back to the days of hair metal88 dodge shadow power locks. -- posted image..
raccoon
Posted: August 16, 2007 at 2:04 PM / IP Logged
well it worked great, but I might add the wires were not in the kick panel.
after they enter through the grommet the harness shoots strait up and runs along the top of the dash just under the windscreen.
its a good thing I had the dash board removed, or it wouldn't of been installed.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
